john deere 500-A backhoe
jim peterson
10-15-2005 11:31:14
hello I would like to find out the year of my backhoe the seral number is missing it has a model 93 hoe it has the two handle on the dash for shifting and the engine bearing are dated 63.The dash is to rusty tell if it is power shift. If also has the dozer noseand the motor is gas well that is all i can tell you Jim p.s. it also has a three point
Ken in Mich
10-22-2005 16:10:22
 Re: john deere 500-A backhoe in reply to jim peterson, 10-15-2005 11:31:14
The JD500 were built from '65 to '71. Here is a link that might help you some:
Roy Suomi
10-15-2005 20:14:26
I don't think you have a 500.. They weren't made in'63, unless someone installed an early 3010 engine in it.I don't know if 3010 was built in '63. Back then they made an animal called a 2010 . 500-A was made in late 60's . If the machine is a power shift there will be a Forward , Neutral , Reverse lever to the left of the steering wheel . An 8 speed shifter with neutral and park on the right side of dash. There will be a clutch disconnect lever under the left edge of the dashboard . Looking under the machine you will be able to see a powershift control valve with 2 control cables attached to it. On the other side there is a valve with B1,B2,C1,C2,C3 cast into the cover , showing where to check pressures for troubleshooting transmission problems..
jim peterson
10-17-2005 16:35:20
 Re: john deere 500-A backhoe in reply to Roy Suomi, 10-15-2005 20:14:26
roy thanks for reply i forgot to tell you guys that it has jd 500 on the loader i checked the trans and it must be a collar shift the motor has a 4 1/4 bore with would made it a 3020
Roy Suomi
10-16-2005 04:25:34
Sorry , Brain fart!!! There is one cable on linkage that goes to upper part of center section in front of rt. final drive. There is linkage that goes to control valve. Not as I said before about 2 cables. The cable applies the park gear, and the linkage moves the gear ranges in the power shift transmission.It could possibly have a collar shift transmission, which is a manual transmission..
