JD 450B Crawler
Gary Bell
10-16-2005 17:24:27
I'm replacing a broken track idler spring the manual calls for a "special" bolt to compress/secure it for removal and installation. Unfortunately the manual doesn't give the specifications for the bolt. The part number is T16678. Anyone have a clue as to the spec's. thanks
Gary
jted
10-17-2005 16:18:28
 Re: JD 450B Crawler in reply to Gary Bell, 10-16-2005 17:24:27
Gary, Try www.jdparts.deere.com specifications for T16678 are given. MSM is correct about using wrong or inadequate bolts on idler springs, they are extremely dangerous when "loaded". I had a 420 crawler one time and NO ONE would take idler spring off for me. Finally was able to cut bolt with hacksaw covered with a heavy tarp and it still shot through a doorway. (Won,t ever do it again!)
MSM
10-17-2005 09:27:40
Get the correct bolt,the last thing you want is a substandard bolt breaking and letting the spring go.You can lose a hand,or your head when the spring comes out at 150 mph. This is not something to go cheap on!!
