T200 Drive Motor Troubles
GTS
10-17-2005 15:09:34
I've got a 2002 BobcatT200 with approximately 700 hours on it. We use it in a tree service to load logs. After having been parked on a Friday, then sitting over the weekend and being used again on Tuesday, we noticed fluid where it was leaking from the left rear track. The machine was working fine, hadn't noticed any leaks prior. So we trailer it, wash it off at the car wash, leave it overnight to dry so we can see the leak, and it's coming from the drive motor back plate with all the hex head cap it. Take it in to the dealer they say no problem probably just a gasket or seal, we'll fix it. Call comes today saying it needs a new drive motor, they found corrosion and metal shavings inside. Reman drive motor installed and drain/flush the entire hydraulic system - $3600.oo!. Sounds a little fishy to me with the machine having so few hours. Could the unit be damaged that much? What's going on here. Thoughts appreciated.
SAM
