Massey 3366 dozer
TnJoe
10-20-2005 07:19:12
I have a 3366 dozer that stops under load. Engine RPM stays the same. Could someone tell me what the pump pressure should be? At idle it is around 30psi and high rpm it is about 80psi.
Thanks Joe
Norm Dicks
10-19-2006 17:51:58
 Re: Massey 3366 dozer in reply to TnJoe, 10-20-2005 07:19:12
dont know wether u have recieved info yet , have same machine 3366 , transmission pump pressure has to be at least 1000kpa to operate ,if not check filter first, but main cause is pump wear in lower transmision , u can remove this via the lower sump , i am after a new pump . so if you know where i can source one please let me know. regards Norm
