Midge or Beetle Crawler question-Clark rearend?...
crawlerguy
10-27-2005 07:51:21
Hi all..hoping someone can help me-a friend has two "Midge" crawlers, they both use a Clark rearend and both need parts. He has been told many older forklifts also use this rearend but he does not know the actual model of the rearend or what other applications it was used in for sure. Can anyone help out with perhaps the rearend model number or a parts source for Clark rearend parts?...or maybe a forklift parts yard? Any help would be greatly appreciated! Thanks much...
MarkEastDubuque@aol.com or mjaxn82361@aol.com or 815-747-2613
JIM BROWN
10-30-2005 18:05:42
 Re: Midge or Beetle Crawler question-Clark rearend in reply to crawlerguy, 10-27-2005 07:51:21
I have CLARK 3-speed rear ends with trany"s. You can call me at 614-402-0908 Jim
r_d97
10-27-2005 18:17:51
The Clark A-30 transmission was used in Cleatrac and Oliver HG/OC-3, ATC Terratracs from the GT-25/30 thru the 200,3000,400 & 500 crawlers. It was also used in the Case 300,310 and 320 crawlers. This was a very simple 3 speed tranny with reverse. I am not sure the Midget/Beetle crawlers used the Clark A-30.
Edward
jdemaris
10-27-2005 18:58:43
 Re: Midge or Beetle Crawler question-Clark rearend in reply to r_d97, 10-27-2005 18:17:51
To add to the list, other tractors that have Clark transmissions that may be the same or similar, are the Minne Moline BF or Avery BF or Cletrac General wheel tractors and many Bombadier crawler snow-cats. I've worked on a few Beetles and think they are quite different.
old
10-27-2005 16:26:00
I think cletracs also used clark rear ends/trannys.
old
10-28-2005 07:52:43
 Re: Midge or Beetle Crawler question-Clark rearend in reply to old, 10-27-2005 16:26:00
You might try calling Zimmermans he might know what your look for and where to get it and or parts. 717-738-2573. He deals with the cletracs.
crawlerguy
10-28-2005 07:43:52
Thanks everyone for the help so far-I believe he has already ruled out the Avery & Moline tractors but I will look into it for sure. Gives us a place to look anyway! Thanks again!...
old
10-28-2005 08:02:29
 Re: Midge or Beetle Crawler question-Clark rearend in reply to crawlerguy, 10-28-2005 07:43:52
You might try calling Zimmermans he deals with the cletracs a lot and may know where to find what you need. 717-738-2573
