jd 350B crawler
duffey
11-10-2005 09:20:02
I have a 350b loader. My rollers and sprocket are near new, idlers are good, track springs and adjusters are new. It keeps trying to walk off the tracks on the bottom when turning. I am asuming the rails are worn pretty bad causing the rail to walk up on the bottom rollers. Do you agree with what I am saying? Where might I find a newer set of rails without buying a brand new set?
Lavoy
11-10-2005 11:02:58
 Re: jd 350B crawler in reply to duffey, 11-10-2005 09:20:02
I know I fought this with a friend on mine on a 420 crawler a couple of years ago. We rebuilt idlers, checked rollers, and did everything we could think of. Turned out the problem was the rails being worn out. That may or may not be your problem, but it sounds similar.
I have a set of rails with fairly new pins and bushings if you find you need a set.
Lavoy
