JCB rams slipping
clover12
11-11-2005 07:24:25
It seems that all the rams are slipping back could there be a common problem? It's a 1984 1400 backhoe
ajk
11-11-2005 12:49:01
 JCB in reply to clover12, 11-11-2005 07:24:25
I would be checking the cylinder seals,they may not be leaking externally but can be leaking internally,that would be the cause of the rams not holding,it is easy to reseal JCB cylinders you just need a 36" pipe wrench to undo the gland nuts,someone on here was offering a workshop manual on CD some post down.
AJ
clover12
11-11-2005 13:14:09
 Re: JCB in reply to ajk, 11-11-2005 12:49:01
thanks will check this out
