jd 500
jim peterson
11-18-2005 13:35:37
thanks guys for the info on my 500 I think it is a 1964 because of the date on the bearing. well anyway i am just about ready to fire it up. when i took the old battery out the gound was on thepostive side is this right.It is a 12 volt system Ialso a little worry about the pump its ben 13 years sent it was runing .Iwill made sure there is oil in it Jim
MSM
11-19-2005 12:53:32
 Re: jd 500 in reply to jim peterson, 11-18-2005 13:35:37
Probably wouldn't hurt to put new fuel filters on it,fresh fuel and bleed the system before starting.Also unless it has been converted to 12v a 500 is 24 volt same as a 3020 of the same vintage.If it has been converted to 12 v it should have negative ground if it has an alternator.Might pay to do some checking on the electrics.
