JD 350B Track Tensioner Spring Questions
Engine One Eigh
11-20-2005 15:38:01
Need to replace one of the outer springs on the track tensioner for my 350B dozer. Any direction or hints I should know about? Where's a good place on the net that would have replacement spring for less then OEM price of $275.00?
Thanks for the help
John
CH
11-21-2005 19:02:36
 Re: JD 350B Track Tensioner Spring Questions in reply to Engine One Eight, 11-20-2005 15:38:01
I have good used complete springs $125. each you can email
Roy Suomi
11-20-2005 19:21:08
Ever since I had a recoil spring come out of my press and go thru the " crapper " wall, I wrap the spring with a chain and secure it to the press.
jdemaris
11-20-2005 17:17:20
I had to fix many of them, espcecially with our rental 350 crawlers. Usually, it's the bolt that fails rather than the springs. For that reason, I sugest you install a new bolt once you have the tensioner all apart.
As far as any other suggestions? Just make sure you've got a good hydraulic press to get it apart and together safely. Stay out of the way when working on - it's kind of a dangerous item and under a lot of pressure.
ralph oregon
11-20-2005 17:06:33
whats the part # if the 440 is the same i have some. ralph
Engine One Eight
11-20-2005 18:03:21
 Re: JD 350B Track Tensioner Spring Questions in reply to ralph oregon, 11-20-2005 17:06:33
Ralph,
I will look up the part number tommorrow and post it here.
Thanks
