TD-6 starting trouble
lanzboy from Au
11-21-2005 23:10:32
I am doing some work on a TD6 dozer and im wondering if they can be started on diesel from cold. I tried to start it on a 30 degree C day but didnt seem to even fire. The starter motor get hot very quickly also. The reason i havnt tried to start it on petrol is because the carby is full of dirt, water and rust and the maggie doesnt spark. Some sugestions would be greatly appreciated.
bruce christian
12-05-2005 18:38:46
 Re: TD-6 starting trouble in reply to lanzboy from Aus, 11-21-2005 23:10:32
oh do i know why you should also not use ether on the engine to start it either. I bought a crawler that was started with either several times, i do not know how many times someone else started it that way, and well it cracked the whole head everywhere. As hector suggested, i would work on getting the gasoline part fixed quickly. You have to build heat in the machine, oil pressure, a it of water temperature, and then switch it over to diesel.
RAB
11-22-2005 08:47:34
Yeah , that starter is designed for petrol compression ratios. A diesel would need a starter about twice as powerful. Little wonder it gets hot!!
RAB
hector gemme
11-22-2005 01:53:34
HI You have to start on gas first and after transfert to diesel because you gone have probleme with crack ead and burn startor, you should clean carburator and line and check magneto and now I have some td6 parts.HECTOR
