JD 420C with 90 Loader hyd pump question
mc_mike
11-27-2005 16:21:11
I have a JD 420c with the 90 loader, does anyone know how much the loader should pick up? I don't think it will lift more than a ton, and I thought it should lift more. I have 4 counter weights on the back and I can't pick the rear end off the ground with the loader. Probably a good thing, but I have another 90 loader for parts and I could not pick the whole loader up. I was kind of disappointed. This leads me to my next question. The hyd pump, does anyone know the part number or the specs on the orginal pump? I don't think the pump that is on there is the correct one. I was also thinking it might be getting weak. I can't seem to find any numbers on it and I am sure it has been replaced at one time. Can anyone help? Thanks.
FDBYRD
11-27-2005 20:36:47
 Re: JD 420C with 90 Loader hyd pump question in reply to mc_mike, 11-27-2005 16:21:11
MY 420C DOESNT HAVE A LOADER BUT IT DOES HAVE THE SAME HYD.PUMP # AS MY 420T
ralph oregon
11-28-2005 02:42:10
 Re: JD 420C with 90 Loader hyd pump question in reply to FDBYRD, 11-27-2005 20:36:47
the 420C with 90 loader has a bigger pump that comes off the crank shaft, the one off cam gear is too small to work loader. ralph
ralph oregon
11-27-2005 16:41:58
breakaway lift at ground level---4500 # full height lift ----2700 #
