I need help changing all of he fluids in my Cat D7 pony start. Here are my questions.1) Does the pony drain out of a long hortizontal bolt in front of the pony? When I took it out the oil drained out. If not where is the drain plug? How much non detergent 30 weight goes back in??? 2) What about the clutch and gear box behind the pony??? How many compartments are there to check or are these gearcases one unit? How are they drained? There looks to be a dip stick pipe on one case. What oil goes in these and what quanities? 3) How much goes in the big engine? How are the oil filters changed? Looks like you screw off the "cans" like a Farmall M or H. 4) How is the oil clutch drained and how much goes back in?? Use 30 weight non detergent here?? 5) How is the transmission drained? How much goes back in and what type of oil should be used? 6) This has a booster on either the brakes or steering clutches? Where does this oil pressure come from??? 7) What about gear boxes on the cable unit? 8) I think I understand the final drives. 9) Anything else?? Thanks
