J D 350
Floyd
10-19-2001 20:49:32
I got my 350 in deep mud and water. Even with top of track, mabe a little deeper, rear RH side. Got it out, but after about2 hrs of operation 3 days later the clutch is slipping I think. Will I have to clean it all out or are they sealed so I could not messed up? Thanks. for any help. Also does anyone have some manules for a 350?
BFarr
10-23-2001 15:42:32
 Re: J D 350 in reply to Floyd, 10-19-2001 20:49:32
There is a drain at the bottom of the steering clutch housing that should be letting the water, etc. out. It may currently have a 1/4" pipe plug installed and I recommend you remove it. Otherwise you may want to check previous posts on stuck steering clutches to get a rec. on how to flush.
Manuals should be available still at the local dealer
Please keep us posted on your progress
