Caterpillar D4 6V Pony Motor
Bernie
03-12-2000 10:23:08
I need information on the starting sequence. How do I engage the Pony Motor to start the Diesel Engine and then disengage it?
Mike
08-26-2002 13:14:40
 Re: Caterpillar D4 6V Pony Motor in reply to Bernie, 03-12-2000 10:23:08
Posted similer on acmoc. I have a D45T. I dont know if this is right or wrong its what I was taught. My grandfather and my father retired from the USFS as cat skinners. I jump my 6 volt pony with my 12 pickup. It doesnt run the starter long enough to hurt it. Pull the engagment lever up to engage it. (If its sticky engage it while your starting the pony.) Let the pony run 30 seconds to minute to get it going good. Compression release should be in start. Engage the main by pushing the pony clutch lever forward. You may have to be gentale to keep from killing the pony. Once you have the main turning the pony clucth as well as the pony engagment lever should hold themselves. Switch from "start" to "run" on the compression release. With the main throttle shut off let the main spin at least a couple minutes esspecially if cold. The exhaust preheats the air intake for the main and the main should build oil pressure as well as fuel pressure. The intake for the main should get hot. You should be getting white smoke out the main stack. when you think it is warm enough, throttle up the pony (it runs alittle over 3000 RPM), and open the main throttle. I open mine about 1/2 way. The smoke should turn very dark grey to black color. Theroterticly it should jump to life. More often than not it will hit on a couple cylinders maybe even kick out the pony clutch. Rengage it and go again it should start pretty quick. Avoid starting fluid at all cost. If you have to use, it a 1/4 second burst in the direction of the air intake will fire it immediatly. To long of a burst, will send your pistons thru the oil pan, and your head into low orbit! Now that you have the main running, shut off the fuel to the pony. Let it run out of gas. The ponys were notourious for flooding making it harder to start the next time, and worse yet, the the excess gas had a habit of running into the crankcase and diluiting the oil. If at anytime you do flood it, check the oil. If it is raised at all, change the oil. There is a plug at the bottom of each head that will drain excess gas if you do flood the pony. Watch the pony spark plug, Boy would I like to get my hands on the dumb#$@# that designed that one. Anyway the pony bites hard if your not carefull. Hope this helps, if you have any comments email me. Happy Dozing Mike.
Catmandoo
02-21-2001 18:08:21
Bernie,
I've got every amnual for that critter. If you need me to copy and mail you something, just give me a hoot.
CMD
FRED
03-12-2000 13:35:19
start pony moter let it warm up a little. pull back clutch lever pull up pinion lever. if adjusted right it will stay in. push clutch lever forward diesel should turn over. should have said to put compression release in start position first. with diesel turning over advance fuel to idel put compresion release to run. if all is right it will start. the starting pinion will self release. FRED
Trackhappy
03-12-2000 20:00:33
 Re: Re: Caterpillar D4 6V Pony Motor in reply to FRED, 03-12-2000 13:35:19
If you want a full description go to>Link
Cheers
Glenn
