Transmission screen/filter-
TomD3B
12-04-2005 05:44:53
Need some help. I have a D3B, serial # 27Y..... I have changed the transmission oil filter located under the floor panel. However, manual shows a transmission screen, part # 6P1407. None of the manuals shows how to change.
Could someone guide me to finding this screen and how to clean/change.
Thanks,
Tom
TomD3B
12-05-2005 06:03:25
 Re: Transmission screen/filter- in reply to TomD3B, 12-04-2005 05:44:53
Bob/Ont;
Yes you are right, I have a 3F/3R transmission.
Bob/Ont
12-05-2005 07:26:25
 Re: Transmission screen/filter- in reply to TomD3B, 12-05-2005 06:03:25
Tom, there should be a piece of the skidpan that will unbolt for changing the trans oil. Look for a plate that comes off the bottom of the trans. Later Bob
TomD3B
12-05-2005 08:06:16
 Re: Transmission screen/filter- in reply to Bob/Ont, 12-05-2005 07:26:25
Bob;
Don't want to appear dim witted but..... I know that there is a bolt under the machine to drain transmission oil. If I remove that belly pan will I have access to this transmission screen that I have referred to. Sorry but just want to make sure that I'm in the right spot. Removed the belly pans once and what a BEAR to get back on especially when working alone
Thanks,
Tom
Bob/Ont
12-05-2005 11:16:03
 Re: Transmission screen/filter- in reply to TomD3B, 12-05-2005 08:06:16
Tom, look under the machine for a plate about a foot square that will come off of the skidpan. You may have to take a scraper and clean off the mud to see it.
Later Bob
ben brown
12-04-2005 11:19:09
tom remove the floor board then top right corner of the transmission is where the screen is i think it is held in with three bolts in a plate. they are clenable sometime i had to replace one even after i cleaned it seem thy changed them to a little larger screen for better flow
Bob/Ont
12-04-2005 19:22:06
 Re: Transmission screen/filter- in reply to ben brown, 12-04-2005 11:19:09
Ben I think you must have an older one with 3 Forward and 1 reverse speed trans. I think tom's is in the bottom of the trans but have to check this out for sure.
Later Bob
