Komatsu D 21
Trey
12-04-2005 15:20:16
I have been looking at buying a KoMATSU d21, how do these dozers hold up? Does haveing the rubber tracks make the undercarriage last longer? I have heard Komatsu equipment holds up as well as Caterpillar, not sure if this is true. I am also wondering if I go with steel tracks how much a new undercarriage would be for one also?
GL
12-04-2005 19:10:40
 Re: Komatsu D 21 in reply to Trey, 12-04-2005 15:20:16
Be aware that you can't just take the rubber tracks off and install steel tracks. You have to change or machine all of the rollers and idlers to switch tracks. This is a big and expensive job. The only thing that stays the same is the rear sprockets. If you think you need steel tracks, you had better buy a dozer that already has them installed.
