steering problem 931 Catepillar loader
phil FL,
12-06-2005 14:15:32
when pushing down on left brake ,the peddle is hard.
it set over the winter and the left brake froze up, and will not steer.
can i just rebuilt or replace the cylinder?
Bob/Ont
12-06-2005 15:44:11
 Re: steering problem 931 Catepillar loader in reply to phil FL,, 12-06-2005 14:15:32
Phil, first off take all the linkage off. Clean up the threads and lube them so you can adjust the rod ends. Once freed up put them back to the same length as you found them. Then make sure the levers in the Dog Houses on the steering clutch covers move freely. If not take them off and free them up and lubricate them too. It would be more help if you could come back with an app. serial# and a bit more detail of what is happening when you try to steer. Does the peddal move at all? Does the machine steer but very hard? Does the machine want to stop when you try to steer?
Later Bob
phil FL,
12-06-2005 17:13:24
 Re: steering problem 931 Catepillar loader in reply to Bob/Ont, 12-06-2005 15:44:11
the left brak will go down but will not steer
the right is ok serial# 78u 1339653600
320445v38574n169
Bob/Ont
12-06-2005 18:13:19
 Re: steering problem 931 Catepillar loader in reply to phil FL,, 12-06-2005 17:13:24
Okay Phil, if the other side works good you have enough pressure to steer. It uses trans oil pressure. Have you tried to adjust the brakes? If the machine stops when you try to turn they are likely okay if not they likely need adjusting up a bit. There are two covers about 3"x 1.5" held on by two 3/8" bolts(9/16 heads) Take them off and adjust the brakes up a bit. Come on back with what you find.
Later Bob
phil FL,
12-10-2005 08:01:59
 Re: steering problem 931 Catepillar loader in reply to Bob/Ont, 12-06-2005 18:13:19
I LIVE IN FL. , THE LOADER IS AT MY BROTHERS HOUSE IN MD. TALKED WITH HIM TODAY HE IS GOING TO TRY AND FIX IT IN 2-3 WEEKS,I WILL GET BACK TO YOU WHEN HE GETS WORKING ON IT. THANKS FOR YOUR HELP PHIL
Bob/Ont
12-10-2005 17:47:00
 Re: steering problem 931 Catepillar loader in reply to phil FL,, 12-10-2005 08:01:59
Your welcome Phil.That explains the hard winter it sat in, didn't think Fl was all that cold. Email me if you have any problems 104060.414@compuserve.com
Later Bob
