Caterpiller Dozer D7E
Jim Horrocks
12-09-2005 08:39:58
I'd like to find info on a D7E I just purchased. The serial number is 47A 5421-E. I'd like to find an operating manual and a belly pan.
Thanks,
Jim in Oregon
captain_crunch
12-12-2005 19:54:04
 Re: Caterpiller Dozer D7E in reply to Jim Horrocks, 12-09-2005 08:39:58
Try Eric Kronig in Amity Ore 1-800-799-2011 His dad had lots of IH parts but Eric has kinda went to Cat. I ran a D-7E in the woods for about 10 years and they are about the best all-around crawler made in my opinion
hector gemme
12-10-2005 08:48:46
HI I dismantle a 47a motor 2 mounth past and have a block,fuel pump,2 ead, sleeve,piston,crankshaft,oil pump and more.HECTOR
Jim in Oregon
12-11-2005 08:08:36
 Re: Caterpiller Dozer D7E in reply to hector gemme, 12-10-2005 08:48:46
Hector, thanks for the e-mail. I'm really looking for a belly pan and tracks. My Cat has street pads, and I need tracks with 60-70% left on them.
Thanks again.
Jim
hector gemme
12-11-2005 08:49:05
 Re: Caterpiller Dozer D7E in reply to Jim in Oregon, 12-11-2005 08:08:36
HI I am sorry dont have track and just sold the 3 parts belly pan sorry HECTOR
Daveminn
12-09-2005 18:13:33
Hope you have better luck with yours than I had with mine,It worked real good for 25 hrs and then the motor had real bad damage due to 2 of the push rods dissappearing and doing damage to the cam shaft.Real spendy to fix but decided to go ahead and fix.Cant wait to use it next season.Dave A
Towbar
12-10-2005 03:55:27
 Re: Caterpiller Dozer D7E in reply to Daveminn, 12-09-2005 18:13:33
Dave did you find out what cuased it to drop those two pushrods?
Daveminn
12-10-2005 04:45:48
 Re: Caterpiller Dozer D7E in reply to Towbar, 12-10-2005 03:55:27
The 2 front sleves that the push rods set in are bolted to the block via. a fork that holds the 2 sleves to the block.The fork pulled out when 1 of the bolts stripped itself out and push rods dropped down into the cam.The two sleves had been wearing in the block for some time and the block needed to be bored out to repair.Engine had to come out,cost me $1000.00 to have a cat dealer come out and take the head off to see the problem.They did not want to touch that old a machine,luckily I found an ex cat machanic near me that knew how to do the work needed so that helped.The only thing is I spent $16000.00. on the machine and now its going to cost me another $10,000. to fix.Dealer I bought it from dosent want to help seeing it was not anything he knew about,Wish he would be willing to help some but guess I will have to bear this alone!Good luck on yours,Dave A
Den BC
12-09-2005 14:08:15
Hello,
According to my "Former Models" Cat spec.book D7E Ser.# 47A's were built from 1961-68 w/160HP DD trans.Machine weight 32,590lbs.
Also built from 1966-69 w/180HP DD trans.Machine weight 33,500lbs.
Towbar
12-09-2005 11:55:02
Jim I may be corrected by someone access to parts books and manual. I think by s/n it is most likely 180hp Direct Drive if so you will find it to be a real work horse and a good all purpose tractor. If I sound biased its because I am. I operated a 47A 51XX which was a 180hp machine from '66 to '79 and have no complaints about same, as it would do what I asked of it.
Jim in Oregon
12-10-2005 07:44:42
 Re: Caterpiller Dozer D7E in reply to Towbar, 12-09-2005 11:55:02
Thanks for the info on the Cat. I will be looking for a site to find used parts.
Thanks again,
Jim
