Case 550 Slow Blade
bh
12-12-2005 08:46:40
I need to do a little work to my 550 Case dozer this winter. When I bought the machine it had recently had a hydraulic pump failure and they had replaced the pump. One of the blade functions was sticky and they had to clean out one of the control valves. The problem is that the blade is slow to react if the motor isn't reved up pretty good. I thought this was probably normal until I operated a 450d that wasn't this way at all. On this machine the blade operated very well even with the motor barely above idle. Where do I start to find the problem. Oil and filters have been changed. Thanks, BH
