955 traxcavator
mike Killian
12-12-2005 18:39:43
loose bolt in transmission case knocked hole through bottom front causing massive oil leak however trans appears to work ok.(9/16 bolt)No recent work done on tran. I found bolt inside trans near the hole. I suspect bolt wedged under the lowest gear and knocked hole in housing.Should I weld up hole and not worry where bolt came from?
hector gemme
12-13-2005 02:08:09
 Re: 955 traxcavator in reply to mike Killian, 12-12-2005 18:39:43
HI Like said BOB you should pull out the transmission and make inspection. HECTOR
Bob/Ont
12-12-2005 21:25:28
I think you better pull the trans and take it apart Mike. There is never just one loose bolt, something is coming apart. Maybe you caught it before total destruction happened. Get that resolved then weld the case.
Later Bob
