Cat .D7 3T jumps out of gear
Tim Dodds
12-19-2005 06:04:10
I have D7 3T that will not stay in 1st or 3rd gear when under a load? Can this be adjusted or does the transmission need to come apart to fix.
Tim Dodds
12-20-2005 13:45:25
 Re: Cat .D7 3T jumps out of gear in reply to Tim Dodds, 12-19-2005 06:04:10
Thanks guys! I pulled the floor pans and found the linkage had lost the cotterpin and came out! Easy fix! Works great.
Have a Merry Christmas!
Ladell
12-19-2005 12:36:25
Tim, Sometimes those locking pins get worn. More or less rounded on the end. Replacement is fairly easy. Requires removal of the interlock housing on the side of the tranny. Easy to replace they just slide in and out, you"ll need a gasket the pins and maybe a little gear oil.
Bob/Ont
12-19-2005 11:38:16
Tim the interlock is connecter to the master clutch lever by an adjustable rod. It is to lock the shifter rails in place untill the clutch is released.
Later Bob
hector gemme
12-19-2005 09:07:36
HI That should be the inter-lock ajustement. HECTOR
