early 955 Traxcavator
Ed Spain
12-27-2005 16:58:31
I'm looking at possibly buying a 955 ser#12A6241 but I know very little about what I need to check or look for. Was this a very good machine? Do you know the specs on it? Any help would be greatly appreciated. Thanks Ed
hector gemme
12-28-2005 08:46:01
 Re: early 955 Traxcavator in reply to Ed Spain, 12-27-2005 16:58:31
HI The 955 12a has a 315 motor like d4-- 7u with poney motor and some have a traction d4 and some have d6 traction and I have some use parts for this machine.HECTOR
KEITH PEHLE
02-05-2006 05:30:19
 Re: early 955 Traxcavator in reply to hector gemme, 12-28-2005 08:46:01
IN NEED OF A GOOD HEAD 955 12A S#4275 CAN YOU HELP .THANK YOU K.P.
Ed Spain
12-28-2005 09:39:23
Hi Hector, thanks for the reply. I looked it over. The springs on the tracks are both broken. The pins on the track are good on the right side and has 39 plates, the left side pins are worn through some what but they still have a good side. Would you be able to rotate these and salvage them, they are only 38 plates on the left side. Ed
hector gemme
12-28-2005 10:04:43
 Re: early 955 Traxcavator in reply to Ed Spain, 12-28-2005 09:39:23
HI I the boushing are pierce you can not make them rotate but if the boushing are not pierce the specialist shop can do it and you have to installed one more link --39 and for the spring rod you have to change them or buy use complete spring and have 2 if they are d4 traction.HECTOR
