case 530 forklift like backhoe
Greg Lasher
01-01-2006 17:17:30
Hello
I have a Case 530 forklift (it looks like a tractor truned around backwards) -- this may be a dumb question but how do you drain the oil from the transmission. I found a big plug on the bottom of the transmssion but has a rubber stopper up in it. When I pulled the stopper I found that it was a blind hole -- it did not go into the transmssion. There must be another plug but I don't see it. I see the plug under the reverser in the torque tube it that's what you call it but that is a seperate casiting from the transmission. Could the plug be on the differential cover covered up by the hyd. res. for the forklift??
Thanks
Greg
