AC HD5 transmission
Rock Picker in
01-01-2006 19:22:49
Can the input shaft bearing and seal be replaced without removing the tranny from the machine? Mine leaks badly around the shaft. After using the machine for about 4 hours, it requires 1 to 2 quarts to bring the oil level back up to the "check-hole". Since the tranny holds 5 gal of oil, will it hurt it to run it two quarts low on oil?
Thanks..... ..... ....RP
hector gemme
01-02-2006 09:25:07
 Re: AC HD5 transmission in reply to Rock Picker in MO, 01-01-2006 19:22:49
HI You can change the boot seal but dont think you can change the bearing and I have those parts. HECTOR
