#12 cat grader
ronnie269
01-05-2006 13:37:42
#12 8T cat grader got to where it wouldn't go in gear (grinding) Pulled the engine and found the through-out bearing was bad. Cleaned everything up replaced with new bearing, still does the same thing, advice from anyone?
Thanks: Ron
ronnie269
01-05-2006 21:50:14
 Re: #12 cat grader in reply to ronnie269, 01-05-2006 13:37:42
Tom, sitting in the seat, would that be the lever coming out of the bell housing with a spring on it on the right hand side?
ronnie269
01-05-2006 21:46:12
Larry, both were good and clean
Doc Larry
01-05-2006 18:53:49
Did you check the pilot bearing/bushing?
Larry
Tom Graham
01-05-2006 17:14:32
Is there a transmission brake that needs proper adjustment? Been awhile since I've been arund an 8T
