cat 9U 1968 cable
mike rose
01-06-2006 11:36:46
Any information on a old cat would be helpful, it's a 1968 9U, 98HP? cable operated, direct drive. Any information helpful
hector gemme
01-06-2006 12:20:33
 Re: cat 9U 1968 cable in reply to mike rose , 01-06-2006 11:36:46
HI The d6 9u was built to 1947 to 1959 give me the serie number I can give your dozer builted HECTOR
mike rose
01-06-2006 19:47:23
 Re: cat 9U 1968 cable in reply to hector gemme, 01-06-2006 12:20:33
The number on the motor is 9U26094 Thanks
hector gemme
01-07-2006 02:32:43
 Re: cat 9U 1968 cable in reply to mike rose, 01-06-2006 19:47:23
HI Your dozer is a 1958 and I have some use parts for. HECTOR
mike rose
01-07-2006 05:50:19
 Re: cat 9U 1968 cable in reply to hector gemme, 01-07-2006 02:32:43
What does the 9U mean? Does it mean that it is narrow? How much does it weigh, with a blade? And what sort of parts you got? Any rollers.. idlers. thanks Mike
hector gemme
01-07-2006 09:24:06
 Re: cat 9U 1968 cable in reply to mike rose, 01-07-2006 05:50:19
HI The 9u is the modeL and the weight shipping 16725 lbs + hydrolique systeme=23000lbs and have some new and use rollers and have parts for motor,startor engine,cluch,transmission,stering cluch and final drive,no more sprocket,idler and chaine.HECTOR
mike rose
01-07-2006 18:20:11
 Re: cat 9U 1968 cable in reply to hector gemme, 01-07-2006 09:24:06
Yep its a 58. Run's like clock, looks like the only thing I need is a boot, for the gear shifter. Know were I can get one? What's this thing worth? thanks Mike
mike rose
01-07-2006 10:12:46
Well I'm going to go test drive her hear in a minute. She looks good. Thanks again for tha info.
never do
01-06-2006 11:51:50
You dont have a 1968 9U caterpillar. Made thru the 40's and 50's....they are a good dozer, Maybe a 48 9U not a 68
mike rose
01-07-2006 10:19:00
 Re: cat 9U 1968 cable in reply to never do, 01-06-2006 11:51:50
Thanks for the info. going for a test drive.
