john deere 310a oil pump removal
captfatboy
01-08-2006 13:11:52
can some one tell me to remove the oil pump do i need to remove the bolt/nut to the idler gear.. am replacing all the barings and have to remove the pump housing to remove the front main barring cap..
dont want to take to much off and take a chance of messing up the timing... thx...
Jonathan in MA
01-09-2006 15:36:59
 Re: john deere 310a oil pump removal in reply to captfatboy, 01-08-2006 13:11:52
If you do have to remove the pump housing , remove the nut on the shaft . Its usually staked on the threads, so it may come off a little hard. Then get 2 small to medium chisels of equal or near equal size. Tap them in on either side of the shaft on the outer portion of the drive gear. This will be between the gear and the front plate of the engine. Eventually the gear will pop off when you least expect it and one of the chisels will hit you in the head on its way down !! So be prepared. If there are balancer shafts just remember to position that one that the oil pump gear drives correctly on reassembly. They will be timed the same from side to side... If the left one is at 6 o'clock then the right one is at 6 o'clock... they rotate opposite each other so if its at 3.o'clock then the other is at 9 o'clock position ... etc ...
captfatboy
01-13-2006 10:02:55
 Re: john deere 310a oil pump removal in reply to Jonathan in MA, 01-09-2006 15:36:59
hehe yea you where soooo rigtht I did dodge the
chisel and yes it was close ... darn gear did pop of the oil pump and counter balance did move thanks so much for in cluding the timing for them...I needed it .. got all the baring in need to tork and then move on to the sleeves and pistons I hate to ask but any more addvise in that area would surly get you front row seats
at our thankyou party
capatfatboy
01-09-2006 20:50:04
Johnathan thanks just as soon as I get back in will try that and also to dodge the chisels
thanks for the tips ..have done alot of work on recip ,,,aircraft cars boats ect but this is my first in the world of diesels really apprieciate it
captfatboy
jdemaris
01-08-2006 19:01:30
Unless I getting senile, you don't have to remove the oilpump to get the front main-cap off. Just take the back cover and tube off of the oil pump by removing the four bolts and you'll have enough room.
