Cat 613 scraper
Z6562
01-11-2006 15:20:34
Cat613 Elevating Scraper are they worth buying.Do they have enough power.
MSM
01-11-2006 16:20:07
 Re: Cat 613 scraper in reply to Z6562, 01-11-2006 15:20:34
They are good little scrapers for dirt only,don't try to use it in rocky ground.Probably the best thing around for stripping topsoil.Don't use a dozer to push load it. They load alot faster if the center cutting edge has the toothed edge.They are adequately powered with a 3208,fairly easy on fuel. Just check the chains and sprockets on the loading chain,they get pricey if worn out. The flights can be welded up if showing wear.
