logskidder engine
2x4
01-18-2006 22:44:20
timberjack 450c has cummins 6BTA diesel engine. water in the radiator goes straight into the oil. Looks like the engine froze with water in it. Busted block? bad gasket? What will it take to fix?
tokes
02-07-2006 04:29:56
 Re: logskidder engine in reply to 2x4, 01-18-2006 22:44:20
a good way to find leaks is to pull the oil pan if you can, and pressureize the cooling system. I use an air regulator set to about ten or fifteen pounds,of shop air, then i connect it to the over-flow hose on the radiator.the air passes through the little check valve in the cap, and the radiator cap makes sure that the pressure dosen't get out of hand.
then if you are lucky enough to to get the oil pan off, you should be able to spot your leaks.
this set up works great for finding almost any kind of water leak,like waterpump seals hoses radiator hoses etc
bcPA
02-01-2006 21:12:23
yes oil cooler is a good suggestion. also on my list injector sleves if this eng has them. My 855 cu inch cummins does along with cracked block and head.
Bentwrench
01-28-2006 15:44:46
I would probably look as the oil cooler first. Pull it and have it pressure tested. If its good I would pull the engine oil pan and then put water in the radiator. If the block is broke it will show up there quickly.
JV3CII
01-19-2006 13:16:26
Hi. Make sure there aren't any core plugs inside the engine. Had this problem with a David Brown tractor a while back. Turned out there were 2 core plugs under the rocker cover. Don't know if Cummins ever used this daft idea though...
old
01-19-2006 06:56:30
Could also be a cracked sleeve. I have that problem on my 190/220 cummins engine and haven't been able to find a good sleeve and piston for it.
mike j
01-20-2006 22:05:38
 Re: logskidder engine in reply to old, 01-19-2006 06:56:30
Hi old is that the 743 cid engine let me know i may have a sleeve and piston mike j
old
01-21-2006 06:29:05
 Re: logskidder engine in reply to mike j, 01-20-2006 22:05:38
That I don't know, I do have the sleeve number that I could send you and if they match then it would work, thats my problem I have yet to find one with the same numbers.
the tractor vet
01-19-2006 07:10:39
The 4bt and 6 bt cummins does not have sleeves so this fall under the heading of ( HUSTON WE HAVE A PROBLEM HERE ).
