track adjusting
MARK MACHADO
01-20-2006 15:35:07
I have a D6 9u Cat. I have taken the track off and the track adjuster will not go back in for i can pin the track back up. It will have to go back about 3 inch. I took the grease zurt out and tryed to pull it back will not move, It looks like there are treads on the adjuster? So how do i move the adjuster back? thanks for all your help
Bob/Ont
01-20-2006 17:55:06
 Re: track adjusting in reply to MARK MACHADO, 01-20-2006 15:35:07
They had mechanical track adjusters but many where converted to the optional Hyd/ grease type adjusters. A pic would help us tell what type you have.
Later Bob
MARK MACHADO
01-20-2006 19:29:27
 Re: track adjusting PICS in reply to Bob/Ont, 01-20-2006 17:55:06
HOPE THIS HELP
http://www.putfile.com/machadoranch
Bob/Ont
01-20-2006 19:37:55
 Re: track adjusting PICS in reply to MARK MACHADO, 01-20-2006 19:29:27
Mark, that looks like a mechanical screw type adjuster to me. The grease fitting is to lube the threads. Try loosening the bolts and nuts at the idler yoke and turning the extention rod to move the idler back. You need it a lot slacker than it was to couple the track back up.
Later Bob
MARK MACHADO
01-20-2006 19:55:38
 Re: track adjusting in reply to Bob/Ont, 01-20-2006 19:37:55
Bob, thanks for your help if i cant move the adjuster rod can i put a little heat to the threads for i can break it loose with out hurting anything in side., Mark
