188 diesel injector adjustment
smilie
01-24-2006 09:07:03
can the average guy with a mechanical background set/adjust diesel injectors. i have a case 310g crawler with a newly rebuilt 188.
John Van Valkenburgh
01-25-2006 02:51:16
 Re: 188 diesel injector adjustment in reply to smilie, 01-24-2006 09:07:03
I pondered this when I rebuilt my 188. I ended up getting a set of "refurbished" injectors for something like $50 ea. I'm told that they can't really refurbish these injectors but they instead clean them up, test and adjust them. The injectors I ended up with have worked fine.
The local case dealer offered to test and adjust my injectors if I wanted to. They have a special test stand that they use. The main reason I went with the "refurbished" units is becasue I did not know the history of the engine and the old injectors were pretty carboned up and would have needed to be taken apart and cleaned up anyway.
Best of luck,
John
1968 Case 450
JV3CII
01-24-2006 12:49:17
Hi. With the right information and access to a jerk pump to test the pressure settings of the injector, yes most types can be adjusted and set. If they need more than just a pressure adjustment, I'd recomend not doing it yourself and handing over to a specialist. John Deere's Fundamentals of Service series gives quite a detailed rundown on injector servicing in the Engines edition. Or at least the edition I've got does, but it dates to about 1970...
Cheers, JV3CII.
the tractor vet
01-24-2006 12:43:59
Not with out the special tools and the tester.
smilie
01-25-2006 12:54:19
 Re: 188 diesel injector adjustment in reply to the tractor vet, 01-24-2006 12:43:59
thanks guys, sounds like i should opt for letting someone else do the job.
