Joe, Thanks again for the input! Before you responded, I had called another NH dealer and spoke with a guy with 25+ years of experience there. Just like you stated, he said that the only thing downstream of the filter is the cooler, and that the hoe can generate 2700+ psi. He said that he never checked the pressure, but that it is possible that the pressure could get greater than 60psi. How much, he didn"t know. But, your statements seem to match, so I may have nothing to worry about.I also told him that the previous owner had plugged and subsequently crushed the pump inlet filter screen in the reservoir. The previous owner replaced it and made the appropriate repairs, however, the NH guy told me that the cooler could have gotten gummed up from packings(?) when the screen got crushed. He said that it"s possible that the cooler is causing the restriction, and that it may be good to "boil" it at a radiator shop to remove any gunk. He also said that the high pressure would subside after the fluid warms up (it was about 20-30F when I got the high pressures), but that it would also increase at higher RPM (I had the 60+psi at idle, and never revved it up). Makes sense to me. I know that the relief valve is properly installed, since it"s integral to the filter housing, and the flow direction on the housing is correct. I think my next step is to check the actual pressure (as opposed to the idiot gauge I have now), and see what I get. I think that if it"s anywhere under 200psi, I"m not going to worry about it. Otherwise, I think a cooler cleaning may be in order. Thanks, JB
