Root/ brush rake for TD6
Michael Naylor
01-28-2006 21:26:51
Does any one know where I can get a root/brush rake for my TD6 that does not cost a fortune? Thank you. Mike
Bernie in MA
01-30-2006 16:28:31
 Re: Root/ brush rake for TD6 in reply to Michael Naylor, 01-28-2006 21:26:51
I built mine for my JD 420c. I used a 6 foot piece of I-beam across and welded teeth made out of 1x3 flat bar to it. I cut a 1" wide notch in the bottom flange and put the bar in the notch with the top end under the edge of the top flange, so that the bar was at a slight back angle to the ground. I put pieces standing up on the top side to keep trash from coming over. Been using it almost 50 years. I hardly ever use the blade anymore.
