dresser TD-8E starting problem
Jeff Steinson
01-29-2006 06:47:08
Needs starting fluild to start hot or cold. Runs great. Where would you look first to fix?
DWF
01-29-2006 19:36:23
 Re: dresser TD-8E starting problem in reply to Jeff Steinson, 01-29-2006 06:47:08
I had a TD8-E and had the same problem for some time. After an overhaul and injectors, timing check, everything possible. It was the pump. I bought a rebuilt pump, problem solved! DWF
MSM
01-29-2006 16:16:33
There should be a start position on the throttle lever.It advances the pump and gives it full fuel to start.If you have a manual,check the position for the lever.I think it is between the idle and stop position.
J.Steinson
02-01-2006 15:52:00
 Re: dresser TD-8E starting problem in reply to MSM, 01-29-2006 16:16:33
MSM, you had the right answer.Sometimes one needs a second look. Thanks for you help!
the tractor vet
01-29-2006 07:57:02
First thing would be to have the compression checked then if that checks out good then i would move to the pump and injectors as the injectors may be cracking to low or the cranking presssure of the pump is off because the head is wore out. Nothing that the dollar bill can't fix.
