Final drive replacement??
eganson
01-29-2006 17:12:37
Anybody here ever replace final drives on the Case 310 crawlers? (stuck in the woods and raining) I can't get it off with the track-support plate blocking it... loosen that a little for clearance? Suggestions...??
charles kunau
01-31-2006 17:24:47
 Re: Final drive replacement?? in reply to eganson, 01-29-2006 17:12:37
i have a similar problem but pound and heat and soak i cant get the pin out to break the tracks seems all i can do is spread the ear on the rail
CH
01-31-2006 18:56:48
 Re: Final drive replacement?? in reply to charles kunau, 01-31-2006 17:24:47
Blow it out with a torch and buy a new master
CH
01-29-2006 18:39:15
I have all the parts you need to fix that machine Email me for a link
smilie
01-29-2006 18:20:05
is the housing broken? if not why remove the whole final drive? why not just remove the outer housing and replace damaged parts?
eganson
01-29-2006 20:47:00
 Re: Final drive replacement?? in reply to smilie, 01-29-2006 18:20:05
The housing doesn't look bad on the outside, but once I took off the track & sprocket, the drive shaft fell out. For quite a while it had no bearings at the outer race/drive sprocket, so I'm pretty sure that inner race area of the inner housing is chewed-up and/or cracked. May be saveable later, but I have a complete drive to bolt on...
