JD 450 DOZER/ VALUE AND YEAR
VINNY
01-30-2006 20:42:01
I JUST PURCHASED A 450 FOR 11,500 DID I PAY TOO MUCH??? IT HAS NEW SPROCKETS UNDER CARRIAGE IS ABOUT 85-90% TRACK SEEMS IN GOOD SHAPE NO BLOW BY.
I FOUND THE SERIAL NUMBER WHAT YEAR IS THIS? T5E3M 0742571. AND CAN YOU TELL ME WHAT THE HANDLE ON THE TOP LEFT SIDE NEXT TO THE BATTERY /TOOL BOX IS FOR. PTO?? THANKS FOR ANY HELP YOU CAN PROVIDE.
jdemaris
01-31-2006 07:53:28
 Re: JD 450 DOZER/ VALUE AND YEAR in reply to VINNY, 01-30-2006 20:42:01
I don't know what vintage your machine is and I don't have a serial number chart to date it. Small engine 450s with 6 way blades, in good shape, bring around $7000 - $8000 in my area of central New York. Straight blade machines a few thousand less. Newer 450Bs, Cs, etc. bring a lot more - especially with the bigger engines, turbos, and with the "C"s an newer, wet steering clutches. The location of the HL-R transmission varies with the age of the machine - the oldest 450s and also 2010s having it on the floor between your legs. The shifter handle, on your top-left when sitting, is the range gear transmission shifter - with four speeds. Due to a class-action lawsuit against Deere, an update kit was supposed to be ground into its quadrant to create a neutral position - that includes all 450s and 2010s with HL-Rs.
ddd
01-31-2006 07:40:20
I think thats the foward reveres lever.
