JD 450C Info Needed
Uncle
02-03-2006 21:10:18
I am looking at a JD450c? I have a serial number of: 450C189087T
I am looking for any info. The engine is out and sitting on the ground but everything looks to be there.
Are these wet clutch, Reverser, Year produced, etc.
I forgot my dial calipers at home but the tracks look good and measure 20.25" for three links, are these OK?
Thanks, Brian
CH
02-03-2006 23:24:41
 Re: JD 450C Info Needed in reply to Uncle, 02-03-2006 21:10:18
450C starts at #191829 in 1974. So i would say you are looking at a 450B. The 450C is a wet clutch but the B is a dry clutch. The 450B you are looking at is a late one 1975,as the Bs and Cs over lapped each other. Also you must measure 5 pin bosses Four links and the wear chart is on my web site you can email me for a link to it.A 450 has a 6.29 pitch so your tracks measure about 27 if i go by your three measurement 100% wear is 25.82 I'm surprized you don't see holes in the bushings. I think for a part time machine home owner machine the chart is way to rigid but even at lax terms the pins&bushings are shot and i bet wearing the spockets
