John Deere 450C with winch
Bob Dice
02-04-2006 17:39:12
We just acquired a John Deere 450C with a winch. Does the tractor PTO shaft turn at all times when the engine is running? The winch seems to be broken as there are metal pieces and what looks like chunks of bearings in the winch case. The pto shaft connector between the tractor and winch is missing. The cable that goes from the winch control lever to the winch is missing. We can't find a pto engagement lever on the tractor so we are assuming the shaft turns at all times - right? We'll probably get into the winch more on Monday. We are hoping a bearing or something is binding things up, we'll see. The tractor is a late 70's model with 2400 hours. Looks bad but actually is in pretty good shape. We'd appreciate any info on how the winch unit is supposed to operate. Thanks
MNwebfoot
02-10-2006 09:31:23
 Re: John Deere 450C with winch in reply to Bob Dice, 02-04-2006 17:39:12
if you 450 has a powershift then you push your foot clutch in 1/2 way to disengege the PTO and all the way to shift the main transmission. Adjustment on these clutch linkages are critical when you set them up.The PTO turns at all times with no disengagement.
scot harris
02-07-2006 15:29:13
looking for info myself on JD winches. Have a 450D I'd like to find a winch for for. Hope somebody comes along to give you some info...and I'll listen in.
