JB OH Pressures on Backhoe
JJS
02-05-2006 14:13:06
I put a guage on my return filter yesterday.
It was 30 degrees outside. When I started the tracter, and it ran up to speed (full Throttle) the pressure rose to 250psi. bringing the tractor down to 800 rpm, the pressure droped to 75, held for a few seconds, then started to fall to about 65psi over about 25-30 seonds. I let the engine run for another 20-30 seconds, or so then opened the throttle back up. this time the pressure topped out at 200, for a few seconds, then fell bact to 160. Idled the engine back again and the pressure was running about 55psi. I didn't run the tractor for more than 3 or 4 minutes, which didn't give the oil much time to warm up, which should give lower pressures. Hope this information helps.
Joe
