grouser pads
J.Steinson
02-10-2006 14:03:41
Currently repairing track adjusters on International crawler. Would like to repair grouser pads as are 60% worn.(standard pads). What would be most cost effective way to fix? Where would best place to get parts?
TomA
02-11-2006 18:39:15
 Re: grouser pads in reply to J.Steinson, 02-10-2006 14:03:41
Go to this link and read.
http://www.alliedcp.com/support/faq_griplug2.asp
RodInNS
02-11-2006 14:14:56
Any dealer that handles crawlers and heavy equipment can easily supply "grouser bar". It is simply a formed hardened bar that is ready to weld in place. Steel suppliers would probably have it as well. The last stuff I had, I welded on with a 7018 rod. It was a lot of work. I would say if you can do the job yourself, you'll come ahead, provided the track shoes aren't worn thin too. If you're going to hire this out to a welder, then just save yourself a bunch of money and buy new track shoes. It will be cheaper in the long run.
Rod
smokieborde
02-11-2006 10:30:45
i have seen plates welded on to increase the depth of the grouser
dont know what welding rod used tho
smilie
02-10-2006 15:35:17
don't know where you located, but just priced some out at grace track in iowa.1-800-426-4136
J.Steinson
02-10-2006 15:56:42
 Re: grouser pads in reply to smilie, 02-10-2006 15:35:17
I'll call to see, but I live in Virginia
smilie
02-13-2006 21:22:45
 Re: grouser pads in reply to J.Steinson, 02-10-2006 15:56:42
another guy mentioned in an earlier post an outfit called north american track. i did a search and they are in south carolina. closer to you than grace out of iowa.
