regarding a 6G Allis Chalmers crawler
Doug Ulrich
02-10-2006 16:20:38
I have just bought a piece of property that has an old Chalmers crawler on it. The prior owner says that it worked up to about a year ago. Does anyone know much about this machine and any info on it. I just dont know anything about it, and that is all I can make out on the unit. I see that it says 6G on the back and that it is an Allis Chalmers and that it. Any help would be appreciated.
thanks!
Don BC
02-12-2006 16:48:05
 Re: regarding a 6G Allis Chalmers crawler in reply to Doug Ulrich, 02-10-2006 16:20:38
I know you said that you are not a gearhead but if you cannot tell if it is a gas or diesel engine just by looking at it I think that you should quickly become good friends with a neighbor that is a gearhead that can give you some advice and operating instructions if the machine is running. A dozer is not simple machines to operate and look after if you have no experience.
Doug U
02-12-2006 17:25:27
 Re: regarding a 6G Allis Chalmers crawler in reply to Don BC , 02-12-2006 16:48:05
OH I know! I have a local fella coming out to get it running for me now. I am gonna have him give me some tips on running the thing. I wouldnt even bother with it but I got the thing free. I just basically need it to cut trails in and push some deadfall out of the way. All of this just so I can get my food plots planted in the springtime. I have run plenty of equipment actually, but when it comes to working on any of it I am pretty much no help. In short I know just enough to be dangerous and get the job done. There isnt really anything else that I am gonna need it for. Since it was free I cant get myself to get rid of it. What do you think it would be worth if I(we) get it running again?
Doug
Hector gemme
02-11-2006 01:14:57
HI THE hd6g with 344 allis is diesel 4 cylinder and HE have master cluch dry and stering cluch dry too and I still have parts for this machine. HECTOR
jdemaris
02-10-2006 17:35:25
Weighs around 13000 lbs. not counting attachments such as a dozer blade assembly. Buda 344 cube engine that puts out 60 PTO horsepower. Parts are still available from AGCO or the Buda Engine Company in Lousiana. HD6G is a six roller machine.
Doug ulrich
02-10-2006 18:23:24
 Re: regarding a 6G Allis Chalmers crawler in reply to jdemaris, 02-10-2006 17:35:25
do you think that it would be very expensive to get this thing going if the engine is not locked up? and to keep it mantained?
jdemaris
02-11-2006 07:16:10
 Re: regarding a 6G Allis Chalmers crawler in reply to Doug ulrich, 02-10-2006 18:23:24
Depends on your mechancial expertise and how good a scrounger you are. Parts, used or new are getting very expensive, and so are labor rates.
Doug Ulrich
02-10-2006 17:24:47
what does it have for horsepower and would it be diesel or gas? I really am not a gear head, I just dont know anything about crawlers. I just know that i could really use it to plant my food plots in the spring.
Lee Bradley
02-16-2006 10:07:17
 Re: regarding a 6G Allis Chalmers crawler in reply to Doug Ulrich, 02-10-2006 17:24:47
These machines were only diesel also use 24 volt starting system. Weight for the HD-6G should be around 16,000 pounds. Crawler/loaders are very versatile machines and this one is a very good size; easily moved (no oversize permits) and big enough to do work. If you can get it running, it is worth a fair piece of change.
Hector gemme
02-10-2006 16:28:19
HI The hd6g have a motor 344 allis and you should find the serie number on back housing top right side. HECTOR
