jdemaris
02-15-2006 05:38:31
Re: rating undercarriage wear in reply to jim hynden, 02-14-2006 23:41:48
If you are trying to check over a crawler's undercarriage, especially a dozer from a rocky or hardpan area, or from a logger, you'd better look at more than just wear. Most of the time, important areas of the undercarriage structure are broken, missing bolts, etc. Most times, when we had to go through the undercarriage of a crawler, there was much more time spent on fixing the broken and missing parts than that of replacing sprockets, rollers, etc. And, every specific machine has its own special weak areas. This holds especially true for certain versions of crawlers. For instance, Deere, Allis Chalmers, Cat, and probably many more, offered their crawlers in "flat ground" models, and "rough terrain" models (those are my names, I don't remember the specific terminology). So, some had rigid track-frame fasteners and tended to break, crack, strip bolts, etc., while others had transverse (or vertical with Cletrac) springs to allow the track frames to follow the ground - and they tended to hold up much better. Deere also tried using "floating" frames with no springs, like in the 350s, and they wore something terrible. I was mostly a Deere, Case, and Allis Chalmers mechanic, and take the Deere for example. The 350s in flat sandy areas like parts of Michigan and New Jersey held up very well. But, here in central New York, it is rare to ever find one that isn't broken and welded all over - including the side-frames, track frames, final drives, etc. Another thing to consider is if the crawler has ever been used in a salt-area. I just had the miserable opportunity to work on one, and I'll never do it again. It was a land-fill crawler, so I figured it had an easy job its entire life working on soft flat ground. In a way, that was true. But, the landfill ground was salty, and there's not a nut or bolt that will come off without breaking. After looking up undercarriage parts, I found a listing for "salt rated" undercarriage parts - that's something I'd never noticed before.
