JD350B reverser intermittent
R-cubed
02-18-2006 18:47:45
I am having trouble with my shuttle reverser on my 350B and sometimes I have to double clutch it to get the shuttle to work in reverse. Most of these machines have a reverse in the transmission I presume for emergencies but this one doesn"t have a slot in the upper left gate where reverse is supposed to be. Does anyone know the gears are really there and I could cut a slot in the gate to shift into reverse in case of complete shuttle failure or do I have to get my IH TD24 out to pull it backward?
I think the 350C models didn"t have any reverse gear but this is a B model. I presume I"ll have to take the top off the tranny to see it it"s in there.
jdemaris
02-18-2006 20:21:11
 Re: JD350B reverser intermittent in reply to R-cubed, 02-18-2006 18:47:45
On the "C" models, the reverse gear was left out of the transmission, mainly because the hydraulic reverser was no longer an option - it came as standard equipment. I have no idea why you be doesn't have it - so I also have no idea what you'll find if you pull the trans. cover off. It's kind of shame Deere cheapened the later models by taking out reverse - since gear reverse is stronger than running with the hydraulic reverse - it's the weak point of the reverser. You might get some added use with a weak reverser by turning up the rate of shift. Also, make sure there isn't dirt preventing the clutch-pedal from returning fully. Very often dirt gets stuck behind the contol-lever-arm on the reverser control valve and/or the return spring gets weak.
R-cubed
02-20-2006 10:24:33
 Now I'm really cornfused! in reply to jdemaris, 02-18-2006 20:21:11
I read where the 350C had no reverse due to the shuttle being on all of them but now there's a pix of a C on ebay and it clearly shows a upper left slot in the gate. Then there's another one that's a 350B on ebay with a backhoe that has NO gate and is like mine. I just got a manual on the B and it says it has a reverse gear! They must have all been custom built. I'm going to take the gate loose when it warms up to freezing here and find out the hard way.
