If these are the button head type fittings, that you slide a coupling over they required the use of an Alemite volume pump, to pump in something called track roller grease, which today's equivalent of an 00 grease, like MultiFak and others, see your oil and lube supplier, it's a stringly tacky, similar to chainsaw bar oil in consistency, ( do not use bar oil ) You can find used Alemite volume pumps, Alemite is still in business and they can be bought new as well. Some people have adapted or used a grease gun, but you must be careful regarding pressure as you can blow out the seals on the rollers with a grease gun, a volume pump has a pressure relief and does not operate at high pressures like a grease gun. After re-reading your thread, I am thinking you may also have another type, if they are not the buttonhead fittings, I understand that these require you to take out the plug and fill with 30 Wt. oil. The button head type have a hex shape under the button head a flared kind of mushroom shaped head that the Alemite coupler slides over and attaches to, pressure forces the check valve to open in the middle, the other later type is just a plug if I am correct I do stand to be corrected here, see if you can determine if it is a button head or not and definitely refer the the manual for your serial number tractor. Might be an upgrade and not in the book. I'm not sure about lifetime rollers, if they are one in the same that use the 30 wt oil, I think modern ones are sealed completely. Taking a stab at it here, correct me if I am wrong. First there were the alemite type, I forget what came next and if it is applicable to the 17A series, and is the one that takes 30 Wt., but if the older button head type, that is the procedure. This gets asked a lot, many different preferences on the alemite types,as to what grease can be found and used, as well as what is used to pump it in, you just have to be careful and not use too much pressure on those, I have not done or used mine in awhile though, used to lube them lightly as I wanted to play it safe with the seals, and I was not running it heavily, you certainly want the rollers lubed even if the seals leak.
