4way blade for a D4D
Fsrmerboy777
02-21-2006 04:25:50
I recondition my hyd. two way blade including milling the pin holes out to fit a two inch pin. I will be converting this four way blade to a hyd. instead of a mechanical. I gave the pin holes a .020 inch over sizing but I think this may not be enough to get the full range out of the blade. Currently can only adjust the blade 1/2 as much as I use to. What was the factory clearence for these pin holes? And what size of hyd. cylinder should I use in my convertion?
