Old crawler
Webejeepn
02-21-2006 20:35:57
I wonder if someone can help me identify the make and vintage of an old crawler I found for sale. The owner really doesn't know himself. I'm guessing it was built in the 40's or 50's. It is somewhat small, maybe 12 feet long. It has an odd 4 cylinder engine with a distributor and spark plugs on the right side, and an injector pump and 4 injectors on the left side. It also has what appears to be a "Teal" brand aftermarket hydraulic bucket loader attachment with a pump coupled off the front of the crank. It has the usual stearing clutch handles. The grill is missing, so I havn't found any brand or make of the machine. Any ideas?
Zonie
02-22-2006 21:31:46
 Re: Old crawler in reply to Webejeepn, 02-21-2006 20:35:57
Sounds to me kie a TD6 or TD9 international Harvester.
Hector gemme
02-22-2006 02:41:51
HI This crawler is a INTERNATIONAL AND IF YOU DONT FIND A PLATE IDENTIFICATION IN DASH CHECK NEAR THE INJECTOR YOU WILL FIND THE EAD PART NUMBER AND WITH THIS NUMBER I CAN HELP YOU BUT THAT SHOULD BE A TD6 OR TD9. HECTOR
webejeepn
02-23-2006 10:52:49
 Re: Old crawler in reply to Hector gemme, 02-22-2006 02:41:51
Hey, I found the plate. Its a TD9 with serial #TDCB658. Does the number tell you what vintage it is, and do you have any idea what it is worth? Everything seems to be there except the grill, undercarriage is fair, and I have been told it runs. Thanks, Mike
Milton
02-23-2006 12:34:28
 Re: Old crawler in reply to webejeepn, 02-23-2006 10:52:49
Webejeepn, --- 23 / Feb. / 2006 --- The International TD-9 / S# "TDCB 658" was made in 1940. Milton
Hector gemme
02-23-2006 15:51:09
 Re: Old crawler in reply to Milton, 02-23-2006 12:34:28
HI Like MILTON this dozer should be 1940 and am still have some use parts. HECTOR
