Cat d7 oil problem
John kelly
02-22-2006 02:03:26
Can the oil run into the transmission from the engine on a cat D7 Dozer.
Are there filters to be checked??
Towbar
02-23-2006 04:14:15
 Re: Cat d7 oil problem in reply to John kelly, 02-22-2006 02:03:26
Looklng back at this post this AM I was thinking daily use when I posted last night but that is a lot oil hourly. As the others have said most likely stopped up suction screen in the bottom of trans causing it to pull oil from engine into trans pump by the seal. Good Luck! One other thing you should check is the magnetic strainer it's right under the trans pump.
Towbar
02-22-2006 16:37:27
You might check the engine breather tube and screen as it might be stopped up 'pushing oil by the rear main seal. Some of the 7E's did have the clutch and trans run the same oil although I thought it was on the later s/n tractors. I have operated 2 7E's in the 2000 s/n they both had the clutch by it self. The later 5000s/n tractor the clutch and trans was oiled as one. Good Luck on an easy fix.
John Kelly
02-22-2006 03:14:13
Yes Oil at five /six leter an hour disapearing from engin the gear box is over full
John Kelly
02-22-2006 02:45:36
47A 1249
Hector gemme
02-22-2006 02:31:26
HI W ich model d7 you have. HECTOR
john kelly
02-22-2006 03:23:01
 Re: Cat d7 oil problem in reply to Hector gemme, 02-22-2006 02:31:26
yes it is a high winch model,
The enigine is using about 5 leters of oil per day
with out showing much sign of leakage or smoke,
while the gear box is over ful with oil. Is it possible the oil is getting from the engine to the gear box somehow?
john kelly
02-22-2006 03:36:18
 Re: Cat d7 oil problem in reply to john kelly, 02-22-2006 03:23:01
Hi Ok mabye a bit of confusion here
its an old manual clutch model, 1960's or 70's serial number 47a1249
Any ideas?
Hector gemme
02-22-2006 09:20:42
 Re: Cat d7 oil problem in reply to john kelly, 02-22-2006 03:36:18
HI The 47a has oil stering cluch well that should be pump suction seal.
John Kelly
02-22-2006 16:03:18
 Re: Cat d7 oil problem in reply to Hector gemme, 02-22-2006 09:20:42
Thanks for your help i will try a new seal it is the only thing that makes sense thanks Hector
john kelly
02-22-2006 03:38:21
im looking for a diagram or workshop manual
of the oil flow system. Mabye a blocked filter or seal somewhere giving trouble.
Bob/Ont
02-22-2006 07:01:03
 Re: Cat d7 oil problem in reply to john kelly, 02-22-2006 03:38:21
And also check the suction screen on the steering pump too.
Later Bob
John Kelly
02-26-2006 04:33:44
 Re: Cat d7 oil problem in reply to Bob/Ont, 02-22-2006 07:01:03
The suction screen was the culpet in this case all so put in a new seal in the steering pump but it the suction screen was full of muck spot on thanks Bob.
Bob/Ont
02-26-2006 18:10:22
 Re: Cat d7 oil problem in reply to John Kelly, 02-26-2006 04:33:44
What kind of muck John? Wasn't black flakey stuff was it? Might be brake bands coming apart, they deteriorate from age aswell as wear. If it clogges up again pull the clutches and reline the bands.
Later Bob
Bob/Ont
02-22-2006 06:59:01
If the trans and bevel gear are getting more oil and the engine is going down the trans and bevelgear oil should be black by now. That confirms your problem. On a powershift I would look at the crank seal but I don't think the clutch is common with the trans on a direct drive so maybe the steering pump is picking it up at the shaft seal. Check for black oil in the clutch too and come on back.
Later Bob
