j.d. 9300 backhoe
mark ace
02-24-2006 16:53:11
does anyone have or no of a 9300 backhoe for sale to fit j.d. 350 dozer, also looking for r.h. mount bracket # AT35575 thanks for help !
Tom in Pa.
02-26-2006 15:45:15
 Re: j.d. 9300 backhoe in reply to mark ace, 02-24-2006 16:53:11
I have a JD 9300 Backhoe Attachment for sale came off my 450B but i need the bracket for my ripper attachment in Central Pa.
Jim in N M
02-25-2006 13:51:30
JD makes a bracket that takes the place of the weight rack,it bolts right on and yes the hyd will handle the backhoe.you can use a quick disconect set up. Been there-done that. Jim
R-cubed
02-26-2006 10:53:17
 Re: j.d. 9300 backhoe in reply to Jim in N M , 02-25-2006 13:51:30
Yes, there is a adapter that bolts on the back of the 350 but my dealer says it's no longer made and would have to find a used one. They are not cheap even used. ($500-1000 just for 2 pieces of steel plate?) Also, the Rops attaches to the same holes so it would have to somehow share the holes or get taken off. Since the backhoe seat interfers with the rear screen of the ROPS it probably will have to go. Then my PTO shaft would hit the dadburned thing and also have to go although I could cut a hole for it.
There were two Hyd pumps that came on the 350 the 15gpm and 27gpm. Logic dictates the 27 would be the one needed. I am fixin' to make an adapter that holds the backhoe off about a foot and kill 2 birds with one stone.
DGH
02-26-2006 12:58:41
 Re: j.d. 9300 backhoe in reply to R-cubed, 02-26-2006 10:53:17
I would look for a parts machine that has the adapter and the ROPS that goes with it. I have a 450C with 9300 hoe and the hoe is plenty heavy for it to carry around so I would not even think of making an extension to mount the hoe on unless you like looking at the sky all the time!!
R-cubed
02-24-2006 20:16:27
We have a 9300 backhoe and two 350's a plain and a B model. Am pulling hair out trying to figure out how to attach it. The B has a ROPS which would have to come off, bad news and the other has weights that would have to come off and an adapter and then I'm not sure the hydraulics would handle it. Needs something like 27 GPM at 2300PSI. Bout to give up and attach it to my M but that wouldn't work either. Will sell it if you are anywhere near central Mo.
