Hydraulic problem on Cat D6 9U
Mark Machado
02-24-2006 18:19:11
When I let the blade down it will travel really slow and it dont respond. The blade will go up like it should. But when i hit the lever the blade will go down but it takes a long time. I have tryed to move the lever just a little and then a lot. But the blade just move really slow. I have filled the Hydraulic up and it dont help. I am using a Hydraulic fluid.
Roy Suomi
02-25-2006 04:35:41
 Re: Hydraulic problem on Cat D6 9U in reply to Mark Machado, 02-24-2006 18:19:11
How much slop is in the linkage ?? I've seen them so sloppy that the linkage can't move the lever on the tank .. There is a " bellcrank " attached to the right main frame rail that is famous for wearing out. This " bellcrank " makes the linkage go 90 degrees to the left just above and behind the starter...
Mark Machado
02-25-2006 16:25:15
 Re: Hydraulic problem on Cat D6 9U in reply to Roy Suomi, 02-25-2006 04:35:41
linkage is ok, the rod move the lever on the tank, Is there a filter or screen that might be dirty, the blade will go down but really slow, is there a special fluid
