Scuffed piston in 955
J.Schmidt
02-26-2006 06:04:58
On dismanteling the 955 engine the lower third of one piston and cylinder and sleeve have 5 1/2 inch wide scuffs parallel to the bore and the rod bearing was a little looser than the other 3 but this cylinder apparently was firing OK.What does this mean?We are replacing cylinders and sleeves because of blow by.
J Schmidt
02-26-2006 15:44:11
 Re: Scuffed piston in 955 in reply to J.Schmidt, 02-26-2006 06:04:58
Never thought about the overheating idea since only one(rear) was involved but there was a lot of amorphous debris behind the sleeve when we pulled it.We were thinking there might be a bent crank or rod?
DGH
02-26-2006 12:52:11
Could also be a leaking injector, with fuel washing away the oil in that cylinder!
Greg_Ky
02-26-2006 06:22:49
Sounds like she started to over heat and was shut down before it did to much damage.
